- Daniel: Workflow variables with a number in front cannot be used for conditions in routes. The workflow will stop here and cannot be continued. (3.0.3 451)
- Joget Workflow: Hi Daniel, may I know on how do you write out the conditions? Please follow on in the community forum ya. Thanks.
- Daniel: I.e. " 22_revisionsdone=='true' ". I used underscore in other variables without problems.
Bet regards,
Daniel
  1. Hi Daniel,
    Are you getting any error in your server log?
    1. Hi Hugo,
      where can I find the joget server logs?
      1. Hi Daniel,
        The log file is located in your (Joget installation folder)\apache-tomcat-6.0.18\logs.
        Anyway, the cause of the problem is that the condition will be evaluated in Javascript and as with most programming languages, a variable name should be start with a numeral.
        See http://stackoverflow.com/questions/342152/why-cant-variable-names-start-with-numbers
        1. Okay,
          I don't have to get numeric variables running and I already fixed the case before posting this issue.
          Maybe you implement a regex validation into the workflow designer in a future version, so others don't get stuck in this implementation issue.
          Best regards,
          Daniel
          1. Hi Daniel,
            I don't seem to see the relationship between having variable name that starts with number and having regular expression in writing the condition. Are you trying to achieve the latter?
