hi there i am having following error when building to wflow-app folder. please suggest me a solution
Tests in error:
  testDeletion(org.joget.directory.model.service.TestDirectoryManager)
  testOrganizationChart(org.joget.directory.model.service.TestDirectoryManager)
  testUsersAndGroups(org.joget.directory.model.service.TestDirectoryManager)
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] wflow-jdbc ......................................... SUCCESS [  1.630 s]
[INFO] wflow-commons ...................................... SUCCESS [  0.609 s]
[INFO] wflow-plugin-base .................................. SUCCESS [  3.988 s]
[INFO] wflow-plugin-archetype ............................. SUCCESS [  0.865 s]
[INFO] wflow-directory .................................... FAILURE [ 12.797 s]
[INFO] wflow-wfengine ..................................... SKIPPED
[INFO] wflow-core ......................................... SKIPPED
[INFO] wflow-consoleweb ................................... SKIPPED
[INFO] wflow-designer ..................................... SKIPPED
[INFO] wflow-designerweb .................................. SKIPPED
[INFO] wflow-app .......................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 20.514 s
[INFO] Finished at: 2014-12-24T07:51:30+05:00
[INFO] Final Memory: 15M/175M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.
4.3:test (default-test) on project wflow-directory: There are test failures.
[ERROR]
[ERROR] Please refer to F:\backup\jw-community-4.0-SNAPSHOT\wflow-directory\targ
et\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e swit
ch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please rea
d the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureExc
eption
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR]   mvn <goals> -rf :wflow-directory
F:\backup\jw-community-4.0-SNAPSHOT\wflow-app>clks
'clks' is not recognized as an internal or external command,
operable program or batch file.
    Please refer to the following for further inspection.
    ERROR Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.
    ERROR
    ERROR Please refer to F:\backup\jw-community-4.0-SNAPSHOT\wflow-directory\targ
    Please try to post in appropriate forum category as well next time. Thanks.
