hi jogetian,
please help me, i got some inconsistent workflow behaviour  that running with subflow
in case :
my workflow was built for running diffrent form with efficient workflow design, cause on that case i try to make
child workflow and parent workflow(subflow)
the inconsistent behaviour (or error) is workflow sometime run normaly, which is the form that in subflow directly show up
and sometime when run not normal, is the form not directly show up, but spolling in inbox first (mostly this happen in joget ver 3 but happen 70%:30% on joget ver 2)
this happen in joget ver 2 and ver 3.
i have no idea to fix this, may be on worfklow design or what?
note: i use external form.
child workflow : to set variable to pick a form that want to use
workflow:biaya_kasus
workflow : memo_kosong
parent workflow  : is main workflow (represent as subflow:Subflow123/Subflow)
