APP_TestTabs-1-20200610084236.jwa
Above is an example of the issue.
INFO 10 Jun. 2020 08:08:43 org.displaytag.properties.TableProperties - LocaleResolver initialized to org.joget.apps.app.web.LocalLocaleResolver.
ERROR 10 Jun. 2020 08:16:08 org.joget.web.presence.PresenceManager - java.lang.NullPointerException
at org.joget.web.presence.PresenceManager.leave(PresenceManager.java:266)
at org.joget.web.presence.PresenceManager.sendResponse(PresenceManager.java:118)
at org.joget.web.presence.PresenceManager$2.run(PresenceManager.java:78)
at java.base/java.lang.Thread.run(Thread.java:834)
10-Jun-2020 08:16:30.838 INFO [http-nio-8080-exec-3] org.apache.tomcat.util.http.Parameters.processParameters Invalid chunk starting at byte [72] and ending at byte [73] with a value of [=] ignored
Note: further occurrences of Parameter errors will be logged at DEBUG level.
ERROR 10 Jun. 2020 08:20:12 org.joget.apps.form.service.FormService - java.lang.NullPointerException
at org.joget.plugin.SectionTabs.setParent(SectionTabs.java:51)
at org.joget.apps.form.service.FormUtil.parseElementFromJsonObject(FormUtil.java:250)
at org.joget.apps.form.service.FormUtil.parseChildElementsFromJsonObject(FormUtil.java:328)
at org.joget.apps.form.service.FormUtil.parseElementFromJsonObject(FormUtil.java:261)
at org.joget.apps.form.service.FormUtil.parseElementFromJson(FormUtil.java:168)
at org.joget.apps.form.service.FormServiceImpl.createElementFromJson(FormServiceImpl.java:108)
at org.joget.apps.form.service.FormServiceImpl.previewElement(FormServiceImpl.java:60)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at com.sun.proxy.$Proxy68.previewElement(Unknown Source)
at org.joget.apps.app.controller.FormBuilderWebController.previewForm(FormBuilderWebController.java:154)
at org.springframework.web.bind.annotation.support.HandlerMethodInvoker.invokeHandlerMethod(HandlerMethodInvoker.java:181)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
at org.joget.apps.app.web.GitRequestFilter.doFilter(GitRequestFilter.java:40)
at org.joget.apps.workflow.security.WorkflowHttpAuthProcessingFilter.doFilter(WorkflowHttpAuthProcessingFilter.java:86)
at org.joget.apps.app.web.ExpireFilter.doFilter(ExpireFilter.java:48)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:493)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:137)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:798)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:808)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1498)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
ERROR 10 Jun. 2020 08:20:12 org.joget.commons.spring.web.CustomDelegatingFilterProxy - Request processing failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:982)
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
at org.joget.apps.form.service.FormServiceImpl.createElementFromJson(FormServiceImpl.java:112)
Did you see the exception on the DX Section Tab?
