Is it possible to add more than 1 datalist formatter in one column ?
For example : I need to make format nested list & javascript (change color) in one data column.
      Hi, I do not believe you can add more than 1. If you need more complex formatting you can either use scripting using the Javascript Condition Formatter or Bean Shell Formatter, or develop your own entirely custom formatter plugin.
