I think only the textfield filter is available in community edition as I checked through the open source code at https://github.com/jogetworkflow/jw-community/tree/7.0-SNAPSHOT/wflow-core/src/main/java/org/joget/apps/datalist/lib
Hope that helps. You may need to check out the Professional / Enterprise edition for more filters.
In the documentation: about Datalist Filter shows that there are several type of filters, but after install the community edition, the only available is "TextField". Also, there is not any mention about "only available on Enterprise edition", so I assume that should be included in Community version.
I'm missing something?
Thanks!
