I want to make a form workflow, where the users can chose from a list of items.
I only have this data in xml, can I somehow make it work?
      Hi, I don't think there is a XML option binder available in Joget. You can consider using Bean Shell Form Binder for Options Binder which allow you to write your java code to retrieve from XML.
