Hi Everyone,
I tried both options and I can't get to work.
I'm almost giving up from Joget.
Have you anyone a app example with this solution ???
Please, it had to work on the free edition (Community).
var
functionName = window[field.attr(
"id"
"_add"
The above row is getting the function name so you can use it as a function and pass an object to it (ex: functionName(data))
var
args =
new
Object();
args[
'result'
'{"amount":"1","category":"Medical","claim":"","purpose":"a","date":"11/18/2015","formattedAmount":"$ 1.00"}'
put your args in this format and pass it to the function
functionName(args);
//all code
// the field id is "entries" grid Name
var
field = FormUtil.getField(
"entries"
var
"id"
"_add"
if
typeof
functionName ===
'function'
var
args =
new
Object();
args[
'result'
functionName(args);
see this : Add a new Row in Form Grid using script
Hi Issa,
I really tried to do as you said, but it does not work.
If you could send my an app example, I'll really really appreciate.
I have tried below script to add a row in Form Grid.
You can use jQuery to add a new row using json data.
Sample jQuery used is as follows:
Javascript here to add new row using json data.
<script> $(function(){ //FGid is the formgrid id var grid = FormUtil.getField("FGid"); $(grid).on("change", function(){ //add button $(grid).find("tr.grid-row").each(function(i, row){ if($(row).find("td.grid-action-cell .add").length === 0) { $(row).find("td.grid-action-cell").append("<a class=\"add\">Add</a>"); } }); }); $(grid).trigger("change"); //trigger change to add buttons to the existing rows $(grid).on("click", ".add", function(){ var newRow = $(this).closest("tr"); //json data below is the field id and value when inserting a new row var newRowJson = '{"field1":"testing1","field2":"testing2","field3":"testing3"}'; $(grid).enterpriseformgrid("addRow",{result:newRowJson}); }) }) </script>
Hi Lee,
This works on the free edition ?
I cannot use the advanced grid.
What I would like to do is.
Create a Custom HTML with 5 fields with an integration with a REST API to fill these fields and once is complete, click in a button beside the custom form to add these values to the grid .
I already saw the article Add a new Row in Form Grid using script , however it's very complicated to understand how procedure.
When I run the command
var
"id"
"_add"
]; in the browser console it does not return anything .
I'm already for a week on this, please give me a hope![(wink)](/community/s/8kxef7/9012/cuccqr/_/images/icons/emoticons/wink.svg)
