I can see the server logs the data is there but how to store that data?
      I will assume that you are using JSON Tool
      In this plugin, check out "Store To Form" and "Store To Workflow Variable" section.
      There's also a demo app to digest the returned sample JSON data in the same article if you scroll towards the end.
      You can turn on the debug mode to look at how your data is structured, and massage them accordingly.
      Alternatively, you can also check out the source code of JSON Tool itself directly at https://github.com/jogetworkflow/jw-community/blob/7.0-SNAPSHOT/wflow-core/src/main/java/org/joget/apps/app/lib/JsonTool.java#L162
      Hope this is helpful.
      Thank you.
      Hugo
      1. Manjeet
        Hi Hugo,
        When creating a new list the "datalist builder" is not showing all columns(or can say form fields). why is that and how to fix it?
