Here the e.g of returned data:
"data": [
"id": "7ea",
"title": "log set Ingress Authentication",
"status": "closed",
"source": "abc",
"alerts": [
"type": "Custom",
"description": " defined.",
"first_event": "2018-12-16T08:10:42.068Z"
"created": "2018-12-16T08:17:18.046Z"
And following is the configuration for JSON OBJECTNAME under: PLUGIN CONFIGURATION→STORE TO FORM
data.id
data.title
data.status
data.source
data.alerts.type
data.alerts.description
data.alerts.first_event
data.created
I am getting the data into database table except the alerts: type, description, first_event. Could someone advise how to configure this nested array?
      Hi Manjeet,
      I just had a look at the source code at specifically at line 271 https://github.com/jogetworkflow/jw-community/blob/7.0-SNAPSHOT/wflow-core/src/main/java/org/joget/apps/app/lib/JsonTool.java#L271
          "data": [{
              "id": "7ea",
              "status": "closed",
              "source": "abc",
              "alerts": [{
                  "type": "Custom",
      The current implementation is not expecting to hit an array (alerts) inside the first array (data).
      Alternatively, you can consider using the Form API Builder and get the external system to call upon Joget's to insert the data in.
      Thanks.
      Hugo
