hello,
i've a question about how to retrieve data from database to spreadsheet?
data in database is
column_name : Detail
[{"c_spec_Detail":"(Core i7/Ram 16GB /SSD 512 / VGA 4 GB /u201d) ","spec_Detail":"(Core i7/Ram 16GB /SSD 512 / VGA 4 GB /u201d) ","id":"1ad320f0-c056-4690-9112-cfd368301390","c_spec_Title":"Spec (Desktop Type D2)","spec_Title":"0"},{"c_spec_Detail":"(Core i5/Ram 8GB /SSD 256 + HDD 1 TB / u201d)","spec_Detail":"(Core i5/Ram 8GB /SSD 256 + HDD 1 TB / u201d)","id":"751717f4-27c1-4379-ab41-87c00bc2ae87","c_spec_Title":"Spec (Desktop Type D1)\r\n","spec_Title":"1"}]
form : Show Detail
i use spreadsheet to retrieve data but i can't to get it
my query is : select c_Detail from infodetail where id='#requestParam.id#'
config in spreadsheet form : field id = spec_Detail , spec_Title , Amount
result : it show all data within column_name : Detail but not seperate data as field id. pls look below
spreadsheet form i need :
spec_Detail | spec_Title | Amount
xxx | aaa | 1
how to retrieve and seperate data into spreadsheet form?
thank you everyone.
In your spreadsheet, configure the load and store binder to use Multirow Form Binder
hello,
data in database is
form : Show Detail
xxx | aaa | 1
thank you everyone.
