Hi Team,
I have a one issues when I am using the Ajax Subform.
Problem:
Input text : Enter the project number on the based on project number populate the values in the dropdown list.
Select Box: Populate the list of values once enter the value , input project number field
Using the JDBC binder for retrieve the data under ajax Subform.
Query: I was trying to use the below query but it is not working
  1.  Select c_projectnumber, ipa_number from app_fd_ipadetails where c_projectnumber=#form.ipadetails.projectnumber#
  2.  Select c_projectnumber, ipa_number from app_fd_ipadetails where c_projectnumber=?
Please guide me how to retrieve the details
      Do download and try the demo app using Ajax subform in AJAX Subform#DownloadDemoApp .
      You can use the #requestParam.primaryKey# hash variable (stores the value from the "Parent Field to keep Subform ID" field) in your query, see AJAX Subform#EditAJAXSubform .
