Hello everybody,
I'm using Joget 7.0.30 Community version.
I have a problem with a data in a list I created. In the list on Joget, the date format has the time back by about two hours.
On the server the date is correct and also on the database.
I checked on the Joget settings and the date format is correct and also the timezone.
However, if I go to the properties of the column to set the format, it gives me the Default Format alone. There is no way to insert the Data Format?
I saw this guide:
https://dev.joget.org/community/display/KBv6/Date+Formatter
But I only have default format.
      Hey there,
      I tried 7.0.30 Community version and couldn't replicate your issue.
      What I did:
      I dragged and dropped a date picker (field id: date_requested), created the list (dragged n dropped the date_requested into the canvas), created the userview, launched it, and saved a date. It displays as I input the data though.
      The Date Formatter is available only in the professional / enterprise edition.
      FYI, you can download the pro/enterprise edition and use it. The first 3 users (i.e by default it's admin, cat & Clark) are free to use.
