You can use Javascript to manipulate the datalist inbox hyperlink, for example below (place this code into the userview menu Custom Footer):
<script> $('.column_inboxAction').each(function() { $(this).insertBefore($(this).prevAll('.column_yourFirstColumnIdHere')); }); </script>
Read https://www.google.com/search?q=jquery+Re-order+table+columns
don't quite understand what you mean, unfortunately. Need more details.
Maybe consider using Userview Builder > Settings > theme > advanced > custom CSS to change position?
Seems this article they can resize the datalist column, maybe you can do whatever you intended to do as well?
I have a data list in this list I have a column name edit which is last column My requirement is to put this edit at first column in the table
Please refer attach screenshot
I have a requirement to change the position of Edit Hyperlink at first colum in data list But I am unable to do this
