I have used the following code. But not working.
if (($("input[name='required_air_ticket']").is(":checked")) == true) { $("select[name='travel_class']").removeAttr("disabled"); } else { $("select[name='travel_class']").attr("disabled", "disbled"); }
The above code is in jQuery
Personally, I just use the section visibility to control it.
Thanks Ian
} else {
