Hi, try checking the value for hash variable #binder.dadosrisco.radio_tipoobra# to make sure that it is returning a valid value.
Hi there, yes its returning the expected value. It seems by the error that maybe is the java sintax that is incorrect. Tried alternatives but no success!
Hello, i have a text box and a radio button and i am trying to simultaneously validate the value entered iin the textbox and in the radio (in the form the id of the radio button is radio_tipoobra)
For some reason i cannot make this work, appreciate some help thanks....
import java.util.Arrays;
String id = FormUtil.getElementParameterName(element);
String amount = "";
if(values.length > 0){
amount = values[0];
if(amount.isEmpty()){
formData.addFormError(id, "No value for input!");
return false;
}else{
float amountF = Float.parseFloat(amount.replace(',', '.'));
if((amountF >1000000) && (#binder.dadosrisco.radio_tipoobra# == 'reab')){
formData.addFormError(id, "Error, max value allowef for reab is 1 000 000,00€ ");
return false;
return true;
Error:
