Hi, I do not think there is such a built-in option in the Form Grid. It believe it should be possible to use custom JavaScript to add your own search box and perform custom filtering, but you would need to find a way to code it.
Is there any option or plugin that allows the user to filter on a specific column like in datalist
filters
so when I add a filter on Desc column of value ('des') then only second and forth records will appear
and if I add another filter of value('.jpg') then only the forth column will appear
