Hello, do you mean to change the text color or the texts themselves? As in changing the text "yellow" to the text "purple" for example? Please elaborate.
If you mean you would like to change the color of the text, then you can use some custom JavaScript like https://stackoverflow.com/questions/55487939/how-to-change-text-color-using-javascript.
How should I write Custom HTML ??
