Adding a new field on a form, I want to set it up as a select box field (from a pre-populated table), it seems to be telling me I need to build a datalist binder.  Where can I go to find the directions on how to build that?
      Hi, to pre-populate a select box field there is a related article at Pre-populate Form Select List from External Source.
