Hello
In my app, i use form grids with multirow form binder that reference a form with file/image upload.
It used to work great in joget V6 but in DX7, nothing is uploaded using the Store Binder. But the Load Binder works.
Any one gets the same issue?
Thank you for your help
      Hey Andrew,
      This is really weird but I tried with your Demo App and it still does not work. I cannot upload anything using the Form Grid of the parent form. It only works if I use directly the Subform.
      There is no error showing in console or logs, so I am kind of blocked!
      Thanks for any more ideas you might have
      Best
      Baptiste
      1. Matthew King
        Hi Baptiste, if you are running on Linux, do check that the ".\wflow" folder used by Joget has create-read-write permission. File attachments are stored in ".\wflow\app_formuploads" and ".\wflow\app_tempfile" folders.
      Hi Baptiste
      I tested the Form Grid field element with file and image upload fields in Joget DX and it ran without any issues.
      Kindly try the demonstration app ( APP_form_grid_file_image_upload_dx_kb.jwa ) in Form Grid#DownloadDemoApp on your Joget DX platform.
