I would like to concatenate three fields to one display field in a popup select box. I'm not experienced with beanschell scripting and hash variables.
      You can use SQL script to do that
      E.g
      Concat script
      SELECT t.id, CONCAT(t.firstname, ' ', t.lastname)FROM table1 t
      1. Fronsky
        Can you advise where to place this?
      2. Anas Misbah Shami
        You can use SQL query to load the selectbox
      Thank you. Where do I place that script? In the beanshell of the new displayfield in de list?
      Sorry I'm not that experienced
