If your identification is correct about conflicting library, you can try to exclude it from the wflow-core dependency
Hi, you can try the solutions provided in a similar question plugin with custom email sending.
I am creating a plugin that use to send email using action button in datalist.
When working on the plugin, I got error from this library
So, I tried to include the library by adding below dependency to pom.xml
The result that I got is still Caused by: java.lang.NoClassDefFoundError: when run the plugin.
After that, I tried to update the dependancy to
The result I got is still an error when run the plugin. The error becomes java.lang.LinkageError: which seems like the library have confilct in version.
Any idea how to solve this problem?
