I just discovered Joget but I'm a little lost, I'm reading the documentation to try to understand better.
However, I have a question with what types of applications can Joget be used? I see forms, lists, processes...
I need to set up a web portal that sells B2B online services
I have to put the whole process in place (from order taking to invoicing)
and I would like to know if Joget can do that or should I code an extension for this part of the project?
Thanks for Answer
      You should check out the multi-tenamcy edition. Might just meet your needs. See here - Joget Cloud Edition.
      Probably need to contact them to get more info. Good luck.
        Hi, Joget is an application development platform where you can develop almost any kind of enterprise application, so yes you can develop a B2B portal. As to whether you need to code, it depends on the actual requirements whether you can opt for a full no-code approach or not.
