i want to get value from filed id on my form
      I suppose this is helpful to achieve you requirement?
      Bean Shell Programming Guide#UseasFormOptionsBinder
      You can implement Bean Shell in your Form to get value from your filled Id.
      Sample Expected Result : Form should be able to Load time zone as the select box options.
      Hope it helps!
        You can refer to Bean Shell Programming Guide#UseasFormValidator
        Maybe you can get an idea from something like:
        import java.util.Arrays;
        import org.joget.apps.form.model.Form;
        public boolean validate(Element element, FormData formData, String[] values) {
            boolean result = true;
            //get field 1 value from form data object
            String field1Id = "field1";
            Form form = FormUtil.findRootForm(element);
            Element field1 = FormUtil.findElement(field1Id, form, formData);
            if (field1 != null) {
                //get value of field 1
                String[] fieldValue = FormUtil.getElementPropertyValues(field1, formData);
            } else {
                //ignore if the field 1 not exist
            return result;
