Hi all,
I'm currently using Joget DX On-Demand (Starter) subscription. Today, I encountered an error in the spreadsheet where the formula for numeric columns failed to calculate.
Am I the only one experiencing this issue? Has anyone else encountered the same problem?
Best regards,
Firdaus Amri
      It happens on my end too.
        Hi Firdaus,
        You are not alone.
        I'm using Cloud. I suppose the cloud is using 8.1.1 version.
        however it works fine on the later version 8.0.12 and 8.0.11.
        I have reported this through here : https://joget.com/contact-us/
        hopefully it will be resolved asap.
        Cheers!
        1. Muhammad Firdaus
          I'm also using version: 8.1.1 - build f1421a7
        2. Fabian Barrera
          Hi Muhammad Firdaus  / Ginger   / Azur
            Anybody have an update about this issue ?
          Fabian Fabian Barrera
        3. Muhammad Firdaus
          The issue is still there. For the time being, I have changed the format type from numeric to text.
