I am calling a stored procedure in SQL query tool in process builder. How to save the stored procedure OUT variable value or return value in process builder variable
      To save the stored procedure OUT variable value in a Joget process variable:
      1. Create Process Variable:
        • Create a process variable named procOutput in your Process Builder.
      2. Configure JDBC Tool:
        • In your form, add a JDBC Form Binder.
        • Write SQL to call the stored procedure:
          sql
          {? = call my_stored_procedure(?, ?)}
      3. Map Output to Process Variable:
        • Use a BeanShell script to set the process variable with the stored procedure’s OUT value:
          java
          # Assuming 'outputValue' holds the OUT parameter value workflowAssignment = workflowManager.getAssignment(activityId); workflowManager.activityVariable(workflowAssignment.getActivityId(), "procOutput", outputValue);
      This sets the procOutput variable with the value from the stored procedure.
      A documentation on this in the KB for you to read too : Call Stored Procedure - MySQL#CallingthestoredprocedureinJogetWorkflow
      Hope this helps!
