I tried building the source as mentioned in the Build from source and able to build the wflow-apps directory and then when i tried building the wflow-plugins directory, Im getting build error while its building the wflow-plugin-report directory and the below is the stack trace I got,
 T E S T S
Running org.joget.plugin.report.TestReportPlugin
Configuration read for sharkdb failed!
SharkEngineManager -> Shark engine is being initialized ...
SharkEngineManager -> Problems instantiating core managers - Can't find ToolActivityHandler class 'org.joget.workflow.shark.WorkflowToolActivityHandler' in classpath!
org.apache.maven.surefire.booter.SurefireExecutionException: javax/servlet/http/HttpServletRequest; nested exception is java.lang.NoClassDefFoundError: javax/servlet/http/HttpServletRequest
        at java.lang.Class.getDeclaredMethods0(Native Method)
        at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
        at java.lang.Class.getDeclaredMethods(Class.java:1791)
        at org.springframework.util.ReflectionUtils.doWithMethods(ReflectionUtils.java:396)
        at org.springframework.util.ReflectionUtils.doWithMethods(ReflectionUtils.java:379)
        at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.buildLifecycleMetadata(InitDestroyAnnotationBeanPostProcessor.java:202)
        at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.findLifecycleMetadata(InitDestroyAnnotationBeanPostProcessor.java:190)
        at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessMergedBeanDefinition(InitDestroyAnnotationBeanPostProcessor.java:119)
        at org.springframework.context.annotation.CommonAnnotationBeanPostProcessor.postProcessMergedBeanDefinition(CommonAnnotationBeanPostProcessor.java:276)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyMergedBeanDefinitionPostProcessors(AbstractAutowireCapableBeanFactory.java:743)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:447)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
        at java.security.AccessController.doPrivileged(Native Method)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
        at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
        at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:220)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
        at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
        at org.springframework.test.context.support.AbstractGenericContextLoader.loadContext(AbstractGenericContextLoader.java:96)
        at org.springframework.test.context.support.AbstractGenericContextLoader.loadContext(AbstractGenericContextLoader.java:44)
        at org.springframework.test.context.TestContext.loadApplicationContext(TestContext.java:173)
        at org.springframework.test.context.TestContext.getApplicationContext(TestContext.java:199)
        at org.springframework.test.context.support.DependencyInjectionTestExecutionListener.injectDependencies(DependencyInjectionTestExecutionListener.java:109)
        at org.springframework.test.context.support.DependencyInjectionTestExecutionListener.prepareTestInstance(DependencyInjectionTestExecutionListener.java:75)
        at org.springframework.test.context.TestContextManager.prepareTestInstance(TestContextManager.java:255)
        at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.createTest(SpringJUnit4ClassRunner.java:93)
        at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.invokeTestMethod(SpringJUnit4ClassRunner.java:130)
        at org.junit.internal.runners.JUnit4ClassRunner.runMethods(JUnit4ClassRunner.java:51)
        at org.junit.internal.runners.JUnit4ClassRunner$1.run(JUnit4ClassRunner.java:44)
        at org.junit.internal.runners.ClassRoadie.runUnprotected(ClassRoadie.java:27)
        at org.junit.internal.runners.ClassRoadie.runProtected(ClassRoadie.java:37)
        at org.junit.internal.runners.JUnit4ClassRunner.run(JUnit4ClassRunner.java:42)
        at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:62)
        at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:140)
        at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:127)
        at org.apache.maven.surefire.Surefire.run(Surefire.java:177)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
        at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: java.lang.ClassNotFoundException: javax.servlet.http.HttpServletRequest
        at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:289)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
        at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320)
        ... 46 more
[ERROR] BUILD FAILURE
[INFO] There are test failures.
Please refer to D:\Joget Source\wflow-plugins\wflow-plugin-report\target\surefire-reports for the individual test results.
[INFO] For more information, run Maven with the -e switch
[INFO] Total time: 41 seconds
[INFO] Finished at: Wed Apr 27 09:53:56 GMT+05:30 2011
[INFO] Final Memory: 27M/63M
Am I missing anything here or anyone faced similar issue while building the wflow-plugins, please help in this regards.
Vignesh
  1. Since the error was java.lang.NoClassDefFoundError: javax/servlet/http/HttpServletRequest, I tried installing servlet-api.jar file manually to the maven repository and tried building again, but the same error again.
    Any help in this issue is much appreciated.
  2. Hi,
    I'm also getting the above issue. Has anyone managed to resolve it?
    Thanks in advance.
    Samir
    1. Hi Samir,
      You need to do the following to resolve the issue, add an entry of the class which is missing (in the above case its javax/servlet/http/HttpServletRequest) into the <Import-Package> tag in the pom.xml file and add the dependency details under <dependencies> And rebuild the complete module.
      Hope this should help.
      Vignesh
