Fresh install of Version: 2.0.0 - build 647 installed on Ubuntu 10.10 (MySQL v5.1.49-1ubuntu8)
Setup Users > Manage Groups > Create New Group > Enter Test, Test, Empty > Save > see error below
Any help appreciated!
Thank you,
-Randy
----org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.jdbc.UncategorizedSQLException: Hibernate operation: Could not execute JDBC batch update; uncategorized SQLException for SQL insert into wf_audit_trail (username, clazz, method, message, timestamp, id) values (?, ?, ?, ?, ?, ?); SQL state HY000; error code 1210; Incorrect arguments to mysqld_stmt_execute; nested exception is java.sql.BatchUpdateException: Incorrect arguments to mysqld_stmt_execute
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:583)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:359)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:371)
at org.springframework.security.ui.SessionFixationProtectionFilter.doFilterHttp(SessionFixationProtectionFilter.java:67)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.joget.workflow.security.WorkflowNtlmProcessingFilter.doFilterHttp(WorkflowNtlmProcessingFilter.java:52)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:271)
at org.joget.workflow.security.WorkflowHttpAuthProcessingFilter.doFilterHttp(WorkflowHttpAuthProcessingFilter.java:39)
at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:174)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:236)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:96)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:636)
Caused by: org.springframework.jdbc.UncategorizedSQLException: Hibernate operation: Could not execute JDBC batch update; uncategorized SQLException for SQL insert into wf_audit_trail (username, clazz, method, message, timestamp, id) values (?, ?, ?, ?, ?, ?); SQL state HY000; error code 1210; Incorrect arguments to mysqld_stmt_execute; nested exception is java.sql.BatchUpdateException: Incorrect arguments to mysqld_stmt_execute
at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.translate(SQLStateSQLExceptionTranslator.java:124)
at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.translate(SQLErrorCodeSQLExceptionTranslator.java:322)
at org.springframework.orm.hibernate3.HibernateAccessor.convertJdbcAccessException(HibernateAccessor.java:424)
at org.springframework.orm.hibernate3.HibernateAccessor.convertHibernateAccessException(HibernateAccessor.java:410)
at org.springframework.orm.hibernate3.HibernateTemplate.doExecute(HibernateTemplate.java:424)
at org.springframework.orm.hibernate3.HibernateTemplate.executeWithNativeSession(HibernateTemplate.java:374)
at org.springframework.orm.hibernate3.HibernateTemplate.save(HibernateTemplate.java:699)
at org.joget.commons.spring.model.AbstractSpringDao.save(AbstractSpringDao.java:69)
at org.joget.workflow.model.dao.AuditTrailDao.addAuditTrail(AuditTrailDao.java:11)
at org.joget.workflow.model.service.AuditTrailManager.addAuditTrail(AuditTrailManager.java:32)
at org.joget.workflow.util.AuditTrailInterceptor.invoke(AuditTrailInterceptor.java:52)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.orm.hibernate3.HibernateInterceptor.invoke(HibernateInterceptor.java:111)
at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:89)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy1.addGroup(Unknown Source)
at org.joget.workflow.controller.DirectoryWebController.saveGroup(DirectoryWebController.java:1411)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.springframework.web.bind.annotation.support.HandlerMethodInvoker.doInvokeMethod(HandlerMethodInvoker.java:413)
at org.springframework.web.bind.annotation.support.HandlerMethodInvoker.invokeHandlerMethod(HandlerMethodInvoker.java:134)
at org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.invokeHandlerMethod(AnnotationMethodHandlerAdapter.java:310)
at org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.handle(AnnotationMethodHandlerAdapter.java:297)
at org.joget.commons.spring.web.ParameterizedAnnotationMethodHandlerAdapter.handle(ParameterizedAnnotationMethodHandlerAdapter.java:28)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
... 53 more
Caused by: java.sql.BatchUpdateException: Incorrect arguments to mysqld_stmt_execute
at com.mysql.jdbc.ServerPreparedStatement.executeBatch(ServerPreparedStatement.java:652)
at org.apache.commons.dbcp.DelegatingStatement.executeBatch(DelegatingStatement.java:297)
at org.hibernate.jdbc.BatchingBatcher.doExecuteBatch(BatchingBatcher.java:48)
at org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatcher.java:246)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:266)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:167)
at org.hibernate.event.def.AbstractFlushingEventListener.performExecutions(AbstractFlushingEventListener.java:298)
at org.hibernate.event.def.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:27)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1000)
at org.springframework.orm.hibernate3.HibernateAccessor.flushIfNecessary(HibernateAccessor.java:390)
at org.springframework.orm.hibernate3.HibernateTemplate.doExecute(HibernateTemplate.java:420)
... 85 more
  1. Additionally, wflowdb.wf_audit_trail table exists and contains two rows
  2. Hi,
    Having done a bit of searching, it might possibly be a problem with that specific version (5.1.49) of MySQL. Do you happen to have access to a different version to test with?
    Someone did mention that there might be a workaround by configuring the JDBC connection. You could try going to Settings > System Setup > Datasource and Profile Settings. In there, modify the JDBC URLs to add &useServerPrepStmts=false e.g.
    jdbc:mysql://localhost:3306/wflowdb?characterEncoding=UTF-8&useServerPrepStmts=false
    Not sure if it works, but you might want to give it a shot :)
  3. Thank you Julian!
          Appending '&useServerPrepStmts=false' to the JDBC URLs was the solution.  BTW, I have not tried any testing with different MySQL version since your solution works.
    -Randy
  4. Thank you Julian!
    I had the same problem for several hours, but thanks to your advice of add '&useServerPrepStmts=false' to the JDBC URLs was solved.
    Wilman
