Hello Jogetor guys,
I wrote beanshell script in beanshell tool plug-in. my question is how can call it in my form.
beanshell
        import java.util.*;
	import java.sql.*;
	import javax.sql.DataSource;
	import java.io.*;
	Connection conn = null;
        PreparedStatement stmt = null;
        try
            String userName = "root";
            String password = "";
            String url = "jdbc:mysql://localhost:3307/jwdb?characterEncoding=UTF-8";
            Class.forName ("com.mysql.jdbc.Driver").newInstance ();
            conn = DriverManager.getConnection (url, userName, password);
            if(!conn.isClosed())
            	String sql = "SELECT Count(*) FROM app_fd_application WHERE app_fd_application.c_companyName = '#form.application.companyName#'";
                stmt = conn.prepareStatement(sql);
                ResultSet rs = stmt.executeQuery(sql);
                rs.next();
                boolean exists;
                if( exists = rs.getInt("COUNT(*)") > 0)
                	System.out.println("exists");
                else
                	System.out.println("not exists");
        catch (Exception e)
        	System.err.println("Exception: " + e.getMessage());
        finally
            try {
                if(conn != null)
                    conn.close();
            catch(SQLException e)
BR
  1. Not sure what your question is. Are you trying to populate a form? Or are you trying to set form field values?
    If you're trying to populate a form field try these links:
    [Prepopulate form fields|]
    Prepopulate form select list
    If you're trying to set form field values from within a Beanshell Tool (within the workflow), take a look at this discussion http://dev.joget.org/community/pages/viewpage.action?pageId=8717213&focusedCommentId=8717244#comment-8717244
    This code snippet shows an example how how to update one form field from a Beanshell tool.
    import org.joget.apps.app.service.AppService;
    import org.joget.plugin.base.PluginManager;
    import org.joget.workflow.model.service.WorkflowManager;
    import org.joget.form.model.service.FormManager;
    import org.joget.form.model.Form;
    import org.springframework.context.ApplicationContext;
    import org.joget.apps.form.model.*;
    ApplicationContext ac = AppUtil.getApplicationContext();
    AppService appService = (AppService) ac.getBean("appService");
    String primaryKeyValue="#assignment.processId#";
    //Load the row using the appId, version, form ID and primaryKey value (process ID)
    FormRowSet rowSet = appService.loadFormData("myApp","1","myForm",primaryKeyValue);
    //Get the row data
    FormRow row = rowSet.remove(0);
    //Update the field you want to update with the value
    row.setProperty("customerFirstname","Some fake name");
    //Add it back in
    rowSet.add(row);
    //Update the table
    appService.storeFormData("myApp","1","myForm",rowSet,primaryKeyValue);
