Hi, I have been trying to learn how to use Joget V3 (on Windows7) and would like to install it on my web host so I can access this from anywhere I have internet access. I have not been able to find out how to do this anywhere...(maybe I haven't been looking very good?).
Can anyone point me in the right direction?
Thanks in advance.
    Do you mean that you would like to host it on your own machine? If that's the case, you may want to change the port of your Tomcat's server to 80 and make the necessary forwarding in your network. Then, everyone else should be able to access your hosted Joget by pointing at your IP address. Hope this helps.
  2. What he means is: How do you install (deploy) Joget onto a 3rd PARTY WEB-HOST server where you don't have administration rights?
    Is this possible simply by copying directory structure of Joget installation to the folder where I want to run Joget server? My web-hosting server already has Apache 2.2. + PHP 5.3.6, MySql 5.5. installed.
      Your web hosting account must be capable of hosting Application server connectors such as Tomcat. Of course, you will need your server admin to set it up for you if you do not have administrative access to the server. Hope this helps.
