I'm trying to build a plugin for dynamic user assignment to a task and looking for Java API documentation. Can you please let me know where I could get the documentation?
It would be great if you could provide some working code samples for assigning an user to task, retrieving the workflow variable value and finally posting the workflow variable value to an external url. l believe all these are achievable using plugin but need pointers on building the plugin using API
Thanks much,
Arun
  1. I found Javascript API and JSON API in the knowledge base but no references to Java API.
    It would be really helpful if you could provide the Java API link.
  2. Hi, can anyone please provide the Java API documentation link?
