Hi Guys,
I want to copy workflow process data into a postgres database before completing the process. So I'm trying to implement a Workflow Process Tool Plugin that can load data from FormRow and save using some spring classes available in spring jar. But when the process runs it returns following error. But i found that  SimpleDriverDataSource is available in default spring jar. How can I resolve this error?
ERROR 06 Mar 2015 10:49:33 org.joget.apps.app.web.JsonResponseFilter  - java.lang.NoClassDefFoundError: org/springframework/jdbc/datasource/SimpleDriverDataSource
Caused by: java.lang.ClassNotFoundException: org.springframework.jdbc.datasource.SimpleDriverDataSource not found by nz.net.snap.workflow-joget-archiver [1]
        at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1460)
        at org.apache.felix.framework.BundleWiringImpl.access$400(BundleWiringImpl.java:72)
        at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.loadClass(BundleWiringImpl.java:1843)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
My Plugin class as follow.
 package org.joget.workflow;
import java.io.IOException;
import java.sql.Driver;
import java.util.Map;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import javax.sql.DataSource;
import org.joget.apps.app.dao.FormDefinitionDao;
import org.joget.apps.app.model.AppDefinition;
import org.joget.apps.app.model.FormDefinition;
import org.joget.apps.app.service.AppService;
import org.joget.commons.util.DynamicDataSourceManager;
import org.joget.plugin.base.DefaultApplicationPlugin;
import org.joget.plugin.base.PluginProperty;
import org.joget.plugin.base.PluginWebSupport;
import org.joget.workflow.model.WorkflowAssignment;
import org.springframework.beans.BeansException;
import org.springframework.jdbc.core.simple.SimpleJdbcInsert;
import org.springframework.jdbc.datasource.SimpleDriverDataSource;
public class MyTool extends DefaultApplicationPlugin implements PluginWebSupport {
    private static final String TAG = "MyTool1";
    @Override
    public String getName() {
        return "My Tool";
    @Override
    public String getVersion() {
        return "1.0";
    @Override
    public String getDescription() {
        return getName();
    @Override
    public String getLabel() {
        return getName();
    @Override
    public String getClassName() {
        return getClass().getName();
    @Override
    public PluginProperty[] getPluginProperties() {
        return null;
    @Override
    public String getPropertyOptions() {
        return null;
    @Override
    public void webService(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
        try {
            String action = request.getParameter("action");
            LogUtil.info(TAG, ">>>>>>>action=" + action);
            String processId = request.getParameter("id");
            saveRecord(processId);
        } catch (Exception e) {
            LogUtil.info(TAG, e.getMessage());
    @Override
    public Object execute(Map properties) {
        WorkflowAssignment wfAssignment = (WorkflowAssignment) properties.get("workflowAssignment");
        LogUtil.debug(TAG, wfAssignment.getActivityId());
        String processId = appService().getOriginProcessId(wfAssignment.getProcessId());
        return saveRecord(processId);
    private Object saveRecord(String processId) {
        AppService appService = appService();
        try {
            //Get primary key
            AppDefinition appDef = appService.getAppDefinitionForWorkflowProcess(processId);
            //Get existing data
            String provFormDefId = "my_from_def";
            FormDefinition provFormDef = formDefDao().loadById(provFormDefId, appDef);
            FormRowSet provDataSet = appService.loadFormData(appDef.getAppId(), appDef.getVersion().toString(), provFormDefId, processId);
            String provTable = provFormDef.getTableName();
            LogUtil.info(TAG, ">>>>>>>>>>>>>>>>>>>>>> " + provDataSet.toString());
            try {
                String driverClass = "org.postgresql.Driver";
                String dbURL = "jdbc:postgresql://localhost/workflow";
                String user = "admin";
                String password = "mypass";
                String dbSchema = "public";
                Driver driver = (Driver) Class.forName(driverClass).newInstance();
                DataSource ds = new SimpleDriverDataSource(driver, dbURL, user, password);
                SimpleJdbcInsert insert = new SimpleJdbcInsert(ds);
                insert.withSchemaName(dbSchema);
                insert.withTableName(provTable);
                insert.executeAndReturnKey(provDataSet.get(0).getCustomProperties());
                LogUtil.error(TAG, e, e.getMessage());
            } finally {
                DynamicDataSourceManager.changeProfile("default");
        } finally {
        return null;
    private static FormDefinitionDao formDefDao() throws BeansException {
        return (FormDefinitionDao) AppUtil.getApplicationContext().getBean("formDefinitionDao");
    private static AppService appService() throws BeansException {
        return (AppService) AppUtil.getApplicationContext().getBean("appService");
