Recently I tried Joget v4 and realize that popup select box is not working properly.
The case is when I add values to the popup select box and submit the form, then in the next form or if I want to edit the form it appears showing no value.
Do you guys know what could possibly cause this?
Thanks in advance.
  1. Hi Felix,
    Thank for report this issue but I am not able to replicate this issue. Can you provide some screenshot and steps to replicate it?
  2. Hi Owen,
    Ok, here is my sample case. I have a form to register user to my app like this one
    Then I submit the form to save the data. Later, I come back to edit that user's data and found out everything was right there except for the value in the popup select box and it will appear like this one below.
    The value "Felix" that once was in the popup select box didn't showed up like the others.
    Thanks, Owen.
