Hi Joget teams,
I tried to change the button's value using javascript as below using the HTML form element:
<script language="text/javascript">
$(document).ready( function() {
$("#submit").val("Hantar");
$("#saveAsDraft").val("Simpan");
$("#saveAsDraft").remove();
$("#complete").val("Hantar");
</script>
But there are no changes on the button's value. Attached is my system screenshot.
  1. I've noticed the same thing. In v4 as well, does not look like I can change the button text. Here is my javascript that is in the Custom HTML
    $(document).ready(function()
    Unknown macro: { $("#saveAsDraft").remove(); }
    $( window ).load(function() {
    document.getElementById('assignmentComplete').value= "ABC";
    document.getElementById('submit').innerHTML = "ABC";
    document.getElementById('assignmentComplete').innerHTML = "ABC";
  2. Hi,
    you can use below script to change label of buttons and hiding 'save as draft' button
    $(function(){
    $("#assignmentComplete").val("save");
    </script>
    Write this script in custom html
    You can also hide 'Save As Draft' button by checking 'Remove save as draft' button found under 'Map Activities to Forms'.
    Promod
