Is there a way to read the Workflow variable in the JavaBean plugin with the workflowmanager API? I do NOT want to use #variable.MyWorkflowVar# because I have some characters (return chars and quotes) in the variable that will mess up something like String mystring = "#variable.MyWorkflowVar#";
Thanks.
  • No labels
2 Comments
  1. Hi Paul,
    Yes, below is the example for your reference.
    String value = wm.getProcessVariable(workflowAssignment.getProcessId(), "variableId");
    System.out.println(value);
    Hope it's help.
    Regards,
    Owen
    1. Thanks! This worked great!
