Dear Support,
We find a problem in the joget.
1. We are making form where we are using check box list with beanshell(JDBC). We selected the value and label from database. We saw good and marvelous. But we are using a filter in the select section like this. WHERE '#variable.formvariableID# LIKE c_databasecolumname. We are selected the value what we would like to see. It was running and working good. The form name was :"Hello"
2. We would like to use this Form(Hello)  in another Form(SayGoodBy). We put the "Hello" Form use  by subform.
3. When we are using subflow the filtering not working in subflow.
I show you a exampe
The bean shell code is fully same. In the first picture the form use by direct, the second picture i used by sbuflow. And I see a different values. Beacuse the workflow variable don't get the sublow.
kod.txt    <--- This is the beanshell code, this is the lower part of the picture(HR-TB2)
Could you help me how can i use a subform if i would like to filter by workflow variable?
Miklós
