I need to write a javascript script that reads a calucaltion field in order to show a text but i'm not sure how to point the calculation field itself.
Eg.   Calculation field: 2,45  --> (flooring: 2)
        Text Shown: RELEVANT IMPACT
        Calculation field: 1,23 --> (flooring: 1)
        Text Shown: LOW IMPACT
        Calculation field: 4,00
        Text Shown: MASSIVE IMPACT
Thanks for your help
  1. Hi Roberto,
    You will need to write your own javascript coding to retrieve values from Joget's Form, and to put them into a Custom HTML. Remember to code your script such that it will listen to the affected fields.
    Good luck.
