. While building it from wflow-app ; the spring context does not get loaded and it says that hibernate dialect needs to be explicitly set. Any idea on this? Is there any documentation on the source code on the site?
  <testcase time="0" classname="org.joget.directory.model.TestDirectoryDao" name="testRemoveOrganization">
    <error message="Failed to load ApplicationContext" type="java.lang.IllegalStateException">java.lang.IllegalStateException: Failed to load ApplicationContext at org.springframework.test.context.TestContext.getApplicationContext(TestContext.java:203) at org.springframework.test.context.support.DependencyInjectionTestExecutionListener.injectDependencies(DependencyInjectionTestExecutionListener.java:109) at org.springframework.test.context.support.DependencyInjectionTestExecutionListener.prepareTestInstance(DependencyInjectionTestExecutionListener.java:75) at org.springframework.test.context.TestContextManager.prepareTestInstance(TestContextManager.java:255) at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.createTest(SpringJUnit4ClassRunner.java:93) at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.invokeTestMethod(SpringJUnit4ClassRunner.java:130) at org.junit.internal.runners.JUnit4ClassRunner.runMethods(JUnit4ClassRunner.java:51) at org.junit.internal.runners.JUnit4ClassRunner$1.run(JUnit4ClassRunner.java:44) at org.junit.internal.runners.ClassRoadie.runUnprotected(ClassRoadie.java:27) at org.junit.internal.runners.ClassRoadie.runProtected(ClassRoadie.java:37) at org.junit.internal.runners.JUnit4ClassRunner.run(JUnit4ClassRunner.java:42) at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:62) at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:140) at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:127) at org.apache.maven.surefire.Surefire.run(Surefire.java:177) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345) at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'setupSessionFactory' defined in class path resource [commonsApplicationContext.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1336) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:471) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409) at java.security.AccessController.doPrivileged(Native Method) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:220) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:423) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381) at org.springframework.test.context.support.AbstractGenericContextLoader.loadContext(AbstractGenericContextLoader.java:96) at org.springframework.test.context.support.AbstractGenericContextLoader.loadContext(AbstractGenericContextLoader.java:44) at org.springframework.test.context.TestContext.loadApplicationContext(TestContext.java:173) at org.springframework.test.context.TestContext.getApplicationContext(TestContext.java:199) ... 20 more
Caused by: org.hibernate.HibernateException: Hibernate Dialect must be explicitly set at org.hibernate.dialect.DialectFactory.determineDialect(DialectFactory.java:57) at org.hibernate.dialect.DialectFactory.buildDialect(DialectFactory.java:39) at org.hibernate.cfg.SettingsFactory.determineDialect(SettingsFactory.java:426) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:128) at org.hibernate.cfg.Configuration.buildSettingsInternal(Configuration.java:2090) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2086) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1311) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:814) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:732) at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1367) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1333)
Test set: org.joget.directory.model.TestDirectoryDao
Tests run: 77, Failures: 0, Errors: 77, Skipped: 0, Time elapsed: 164.761 sec <<< FAILURE!
testAddOrganizationParent(org.joget.directory.model.TestDirectoryDao)  Time elapsed: 0 sec  <<< ERROR!
... 20 more
... 36 more
testAddOrganizationChild(org.joget.directory.model.TestDirectoryDao)  Time elapsed: 0.001 sec  <<< ERROR!
    Please refer to the on going thread Build wflow-directory FAILURE for this issue. Thanks!
  2. Hi,
    Did anyone got this issue fixed? I couldn't figure out what I'm missing here, I tried all the options in the other thread and still getting this error.
    Arun
