How to insert data in joget data list by using Java code
      Depends on the source of the data list. If it's form data, you'll need to know the table name and add the 'app_fd_' prefix and for columns add 'c_'.
      For example, if you create a datalist from a Joget Form called Requests (table name: "app_requests") and want to insert data to its "name" field. Your table name in your query should be "app_fd_app_requests" and the column should be "c_name"
      If its from another source, you'll need to know the table and respective columns as normal.
      This might give some insight abit:
      Store Form Field Data to Multiple Tables - Knowledge Base for DX 7 - Joget | COMMUNITY
