The error messages in the logs should indicate the problem. A guess could be that it is due to the data being too large for the db column? https://dev.joget.org/community/display/KBv5/Custom+Database+Configuration#CustomDatabaseConfiguration-IncreasetheLimitofItems/ElementsinForm/Datalist/UserviewBuilderandProcessDesigner
Can you quickly check the server log files if there's any relevant errors shown right after you attempted to save the userview?
Dear Master,
After upgrading from version 4 to 5.x i have a problem with saving userview because of Jasper Reports in userview Joget version 5.xx.
After manual remake with copy paste JRXML at iReport-5.6.0, it's not solving the problem. Error message after saving userview is : "Save failed. Please try again"
Is it because of my large script (almot 2250 rows) at JRXML ??
I clicked already "Use virtualizer for large report?" but still issue..
I have no idea how to solve this...How could version 5 is having such a problem then ver 4...
Please help. Thank you...
