Hi, which joget version you are using? As I know, joget v6 has the Section visibility control based on multiple fields features.
You will only need to set the join type to "And".
How can one reflect data in a section when two conditions have to be met? Eg: show statusA field value in section1 when field ID statusB is ‘true’ and when field ID statusC is ‘false’. I use ‘|’ all the time but only works on validation based on 1 fieldId.
