Hi, if several HTML elements have the same ID and you need select a specific one, in jquery you could use the :eq selector https://api.jquery.com/eq-selector/. So for example to get first input you could use $(
'input#email_wp_employee:eq(0)'
community,
joget generate radio name "email_wp_employee" by
when used jquery select by
it return 1
and when used
it return 2
it return 2
reference standart from https://www.w3.org/WAI/UA/TS/html401/cp0101/0101-RADIO.html
each input have same name but dfferance id.
https://www.w3.org/TR/2011/WD-html5-20110525/elements.html#the-id-attribute
The
id
attribute specifies its element's unique identifier (ID). The value must be unique amongst all the IDs in the element's home subtree and must contain at least one character. The value must not contain any space characters.i think better if joget generate redio by same name but dfferance id for prevent bug and keep standart.
respect
