Hey there,
You can make use of these fields under "Data Linkage" to be able to reference to another table.
You may refer to Subform
Hope this helps.
Hi justin , Form A and B are mapped to the different table.so sub form way is not working ,already i tried that.
Hey there karthi,
A way around this would be to just create another new form, using back the same form table, and just adding the file upload element alone. Then, you can use a subform in Form B to reference the new form.
Hope this helps.
Is there a way to include just the File Upload element from Form A in Form B ?
