I need to display group wise data on the form . Currently I am using the form grid and adding multiples line items.
e.g. See the below tables we should like to display the data like the format common for grouping Set No. column
How to display the data  in the form after saved. One of my user requirements.
Set No.Item CodeItem DescriptionItem QtyUPSSheet QtyMaterialLWGrainDie No.
1-Cover1001Item -12002100
10070Short50
1002item-22002
1003item-31001
1004item-41001
1005item-51001
1006item-61001
      How to connect in html table and display same format.
        Hi, I do not believe there is an option to display the grid in such a format. You could try to use customized CSS to modify the default look of the grid, or alternatively you would have to extend or develop your own grid plugin as in Developing Plugins
