I have Joget running on an Azure VM per the Azure Marketplace installation. I can access Joget on port 8080 just fine. I see that the default database port should be 3307. I have opened up that port on the firewall of the virtual machine. However, I am not able to connect to the database with MySQL Workbench. What might I be missing?
      I discovered and fixed two issues which should be documented in the DX 7 Knowledgebase page for Joget DX 7 on Azure.
      1. The Windows Server firewall does not have ports 3306 or 3307 open when the Joget Azure Marketplace package is installed.
      2. I needed to access the server via RDP and open those ports on the Windows Firewall. I could find no way to do so from the Azure interface.
      3. The root user in the MariaDB is set by default for only localhost access,
      4. I had to download a MariaDB client to the Windows Server and change root access to %.
      If this information had been documented it would have saved me hours of troubleshooting.
