i have a select box (pre-populated) called Priority, with values P1,P2,P3,P4
in the same form i have two date pickers first Date_Occured second Expected_Completion_Date
based on Priority , i want to add 15,30,45,60 days to the Date_Occured date in to the Expected_Completion_Date
my code is so far
$('[name$=Priority]').change(function() {
	var mySelectedValueId = $(this).find(':selected').val();
    if((mySelectedValueId === "P1"))
        Days = 15
    if((mySelectedValueId === "P2"))
        Days = 30
    if((mySelectedValueId === "P3"))
        Days = 45
    if((mySelectedValueId === "P4"))
        Days = 60
	var dateField = FormUtil.getField("Date_Occured");
	$('[name$=SelectedValueId]').val(mySelectedValueId);
	var mySelectedValueText = $(this).find(':selected').text();
	var instance = $(field).data( "Expected_Completion_Date" );
    var date = $.Expected_Completion_Date.parseDate(instance.settings.dateFormat || $.Expected_Completion_Date._defaults.dateFormat, selectedDate, instance.settings);
    date.setDate(date.getDate() + Days);
    $.Expected_Completion_Date.setDefaults(
            onSelect: function( selectedDate )
            updateDueDate(this, selectedDate);
</script>
but im not getting any update on the Expected_Completion_Date date picker.
any help is highly apricated
Thanks in advance
      The variable "field" is not defined.
      The last block has uneven bracket / syntax problem.
      Something is not right with you code.
      The last block to add days to a date, try https://stackoverflow.com/questions/2706125/javascript-function-to-add-x-months-to-a-date
