Not sure if you can configure the hyperlink action directly, but if you can't, then you can also use some JavaScript or JQuery in a Custom HTML to decorate the columns e.g.
<script> $(function() { $("td.column_email").html("<a href='mailto:" + $(".column_email").text() + "'>" + $(".column_email").text() + "</a>"); }); </script>
I have a list with users and i want to hyperlink the email column to send an email, like <a href="mailto:someone@example.com >.
When I use hyperlink action i get an '?' between mailto: and the variable so it's not working.
