Hi, from the logs it looks like you are trying to configure to an Oracle database. You should check to ensure that the JDBC database connection settings to your Oracle database are correct, because it seems that the database connection could not be established.
Hi there, Try to increase your permsize to a larger one to see if this helps. Your current one is "XX:MaxPermSize=128m" Hope this resolves your issue. Cheers
where is this parameter is located
Try to look for C:\Joget-v5-Enterprise\joget-start.bat
Hello,
After just run the setup of Joget enterprise on Windows server 2012 R2.
The tomcat seems is not running. when trying to open the App center.
How to ensure that the tomcat is running wel.. and to have smooth installtion.
Can you please look through the contents of {installation-dir}/apache-tomcat-X.X/logs and see if there's any issue?
Yes there are many issues,
note I tried to run latest tomcat release to run as windos services.
The joget.log files content is:
INFO 08 Nov 2016 11:48:36 org.joget.commons.util.SetupManager - Using base directory: ./wflow/ INFO 08 Nov 2016 12:08:03 org.joget.commons.util.SetupManager - Using base directory: ./wflow/ INFO 08 Nov 2016 12:08:08 org.joget.commons.util.DynamicDataSource - datasourceName=workflow, url=jdbc:oracle:thin:192.168.210.230:1521, user=jwdb ERROR 08 Nov 2016 12:08:13 org.joget.commons.spring.web.CustomContextLoaderListener - ===== Error initializing WebApplicationContext ===== INFO 08 Nov 2016 12:08:14 org.displaytag.filter.ResponseOverrideFilter - Filter initialized. Response buffering is enabled INFO 08 Nov 2016 12:10:18 org.joget.commons.util.SetupManager - Using base directory: ./wflow/ INFO 08 Nov 2016 12:10:25 org.joget.commons.util.DynamicDataSource - datasourceName=workflow, url=jdbc:oracle:thin:192.168.210.230:1521, user=jwdb ERROR 08 Nov 2016 12:10:30 org.joget.commons.spring.web.CustomContextLoaderListener - ===== Error initializing WebApplicationContext ===== INFO 08 Nov 2016 12:10:31 org.displaytag.filter.ResponseOverrideFilter - Filter initialized. Response buffering is enabled INFO 08 Nov 2016 12:10:38 org.joget.apps.app.web.ThreadCleaner - cleaned 44 values in ThreadLocals INFO 08 Nov 2016 12:18:34 org.joget.commons.util.SetupManager - Using base directory: ./wflow/ INFO 08 Nov 2016 12:18:38 org.joget.commons.util.DynamicDataSource - datasourceName=workflow, url=jdbc:oracle:thin:192.168.210.230:1521, user=jwdb ERROR 08 Nov 2016 12:18:42 org.joget.commons.spring.web.CustomContextLoaderListener - ===== Error initializing WebApplicationContext ===== INFO 08 Nov 2016 12:18:42 org.displaytag.filter.ResponseOverrideFilter - Filter initialized. Response buffering is enabled
The catlina. files:
08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.5.6 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Oct 6 2016 20:15:31 UTC 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.5.6.0 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows Server 2012 R2 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.3 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: x86 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Joget-v5-Enterprise\jre1.7.0_76 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.7.0_76-b13 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Joget-v5-Enterprise\apache-tomcat-8.5.6 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Joget-v5-Enterprise\apache-tomcat-8.5.6 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:MaxPermSize=128m 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx512M 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dwflow.home=./wflow/ 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -javaagent:./wflow/aspectjweaver-1.8.5.jar 08-Nov-2016 12:22:27.944 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048 08-Nov-2016 12:22:27.960 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources 08-Nov-2016 12:22:27.960 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=.\apache-tomcat-8.5.6\conf\logging.properties 08-Nov-2016 12:22:27.960 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager 08-Nov-2016 12:22:27.960 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=.\apache-tomcat-8.5.6 08-Nov-2016 12:22:27.960 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=.\apache-tomcat-8.5.6 08-Nov-2016 12:22:27.960 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=.\apache-tomcat-8.5.6\temp 08-Nov-2016 12:22:27.975 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Joget-v5-Enterprise\jre1.7.0_76\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;. 08-Nov-2016 12:22:28.257 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"] 08-Nov-2016 12:22:28.319 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read 08-Nov-2016 12:22:28.335 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"] 08-Nov-2016 12:22:28.335 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read 08-Nov-2016 12:22:28.335 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 945 ms 08-Nov-2016 12:22:28.397 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina 08-Nov-2016 12:22:28.397 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.6 08-Nov-2016 12:22:28.429 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Joget-v5-Enterprise\apache-tomcat-8.5.6\webapps\docs 08-Nov-2016 12:22:29.194 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Joget-v5-Enterprise\apache-tomcat-8.5.6\webapps\docs has finished in 765 ms 08-Nov-2016 12:22:29.194 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Joget-v5-Enterprise\apache-tomcat-8.5.6\webapps\examples 08-Nov-2016 12:22:29.882 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Joget-v5-Enterprise\apache-tomcat-8.5.6\webapps\examples has finished in 688 ms 08-Nov-2016 12:22:29.897 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Joget-v5-Enterprise\apache-tomcat-8.5.6\webapps\host-manager 08-Nov-2016 12:22:29.960 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Joget-v5-Enterprise\apache-tomcat-8.5.6\webapps\host-manager has finished in 63 ms 08-Nov-2016 12:22:29.960 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Joget-v5-Enterprise\apache-tomcat-8.5.6\webapps\jw 08-Nov-2016 12:22:30.038 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkinternalapi-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.038 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkkernel-standard-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.038 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkpartmappersistence-dodslayer-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.054 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkrepositorypersistence-dods-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.054 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkrepositorypersistence-dodslayer-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.054 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkrepositorypersistence-filesystem-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.069 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkscripting-standard-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.069 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharksecurity-standard-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.069 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharktoolagent-standard-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.069 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkusergroup-dods-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.069 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkusergroup-dodslayer-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.085 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkutilities-dods-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.085 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkutilities-dodslayer-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.085 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkutilities-geronimo-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.085 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkutilities-map-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.100 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkutilities-misc-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.100 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkutilities-wmentity-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.100 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkwebservice-asapapi-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.100 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sharkwebservice-wfxmlapi-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.116 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/simple-xml-2.7.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.116 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/simplecaptcha-1.2.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.116 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/slf4j-api-1.7.10.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.132 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/slf4j-log4j12-1.7.10.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.132 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-aop-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.132 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-aspects-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.132 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-beans-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.147 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-context-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.147 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-context-support-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.147 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-core-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.147 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-data-commons-1.6.1.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.147 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-expression-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.164 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-jdbc-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.164 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-ldap-core-2.0.2.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.164 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-modules-validation-0.8.patched.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.164 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-orm-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.164 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-security-acl-4.0.0.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.179 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-security-config-4.0.0.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.179 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-security-core-4.0.0.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.179 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-security-web-4.0.0.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.179 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-test-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.194 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-tx-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.194 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-web-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.194 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/spring-webmvc-4.1.6.RELEASE.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.194 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/sqljdbc-4.0.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.210 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/stax-1.2.0.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.210 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/stax-api-1.0-2.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.210 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/stax-api-1.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.210 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/stdcaches-7.1-1-professional.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.210 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/stdconnection-7.1-1-professional.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.225 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/stdtransaction-7.1-1-professional.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.225 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/taglibs-standard-impl-1.2.5.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.225 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/transactions-3.8.0.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.225 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/transactions-api-3.8.0.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.225 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/transactions-jta-3.8.0.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.241 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/tro-jta-7.1-1-professional.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.241 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/tro-localcontext-7.1-1-professional.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.241 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/truelicense-core-1.31.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.257 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/truelicense-xml-1.31.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.257 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/twexpdl-2.0.1.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.257 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/util-7.1-1-community.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache 08-Nov-2016 12:22:30.257 WARNING [localhost-startStop-1] org.apache.catalina.webresources.Cache.getResource Unable to add the resource at [/WEB-INF/lib/wflow-commons-5.0.8.jar] to the cache because there was insufficient free space available after evicting expired cache entries - consider increasing the maximum size of the cache
The out put of localhost file is:
08-Nov-2016 12:22:29.866 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log ContextListener: contextInitialized() 08-Nov-2016 12:22:29.866 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log SessionListener: contextInitialized() 08-Nov-2016 12:22:54.499 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath 08-Nov-2016 12:22:55.421 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log Initializing Spring root WebApplicationContext 08-Nov-2016 12:23:13.297 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log Closing Spring root WebApplicationContext 08-Nov-2016 12:23:13.313 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log Initializing log4j from [classpath:log4j.properties] 08-Nov-2016 12:23:13.422 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log Printing properties before Javascript servlet, note, the javascript properties might not be initialized yet: ***************************************************** * Owasp.CsrfGuard Properties * * Logger: org.joget.commons.util.CsrfGuardLogger * NewTokenLandingPage: null * PRNG: SHA1PRNG * SessionKey: OWASP_CSRFTOKEN * TokenLength: 32 * TokenName: OWASP_CSRFTOKEN * Ajax: true * Rotate: false * Javascript cache control: null * Javascript domain strict: false * Javascript inject attributes: false * Javascript inject forms: false * Javascript referer pattern: null * Javascript referer match domain: false * Javascript source file: null * Javascript X requested with: null * Protected methods: Empty HashSet * Protected pages size: 0 * Unprotected methods: HashSet size: 1: [0]: GET
* Unprotected pages size: 3 * TokenPerPage: false * Enabled: true * ValidateWhenNoSessionExists: true * Action: org.owasp.csrfguard.action.Log * Parameter: Message = potential cross-site request forgery (CSRF) attack thwarted (user:%user%, ip:%remote_ip%, method:%request_method%, uri:%request_uri%, error:%exception_message%) * Action: org.owasp.csrfguard.action.Error * Parameter: Message = Security Violation. * Parameter: Code = 403 * Action: org.owasp.csrfguard.action.Rotate *****************************************************
08-Nov-2016 12:23:13.547 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log Initializing Spring FrameworkServlet 'dispatcher'
Pls check the logs in the below comments.
