Success !! Thank you Walter
Try this
try to manually delete the log file locale in your Joget Installation Directory. Those files is ended with ".epoch" file extension and files prefixed with "tm". Example: 127.0.1.1.tm4.epoch, tm.out, tmlog4.log.
Reference: Re: Error . No properties path set - looking for transactions.properties in classpath...
Recently i found log messages after starting joget that created every 10 sec :
WARN 01 Apr 2017 00:00:00 com.atomikos.icatch.imp.CommitMessage - Unexpected error in commit
java.lang.NullPointerException
at org.apache.commons.dbcp.managed.LocalXAConnectionFactory$LocalXAResource.commit(LocalXAConnectionFactory.java:201)
at com.atomikos.datasource.xa.XAResourceTransaction.commit(XAResourceTransaction.java:799)
at com.atomikos.icatch.imp.CommitMessage.send(CommitMessage.java:72)
at com.atomikos.icatch.imp.PropagationMessage.submit(PropagationMessage.java:109)
at com.atomikos.icatch.imp.Propagator$PropagatorThread.run(Propagator.java:87)
at com.atomikos.icatch.imp.Propagator.submitPropagationMessage(Propagator.java:66)
at com.atomikos.icatch.imp.HeurHazardStateHandler.onTimeout(HeurHazardStateHandler.java:122)
at com.atomikos.icatch.imp.CoordinatorImp.alarm(CoordinatorImp.java:929)
at com.atomikos.timing.PooledAlarmTimer.notifyListeners(PooledAlarmTimer.java:112)
at com.atomikos.timing.PooledAlarmTimer.run(PooledAlarmTimer.java:99)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Is there someone can help and explain this issue ?
I'm still using Joget V4 at windows 8 with apache-tomcat-7.0.52 and jre1.7.0_51. Thank you..
