Hi -
moving right along with testing the json tool.... have a question regarding workflow variable;
given a workflow variable called "Token", how do we reference it within the json payload. I have tried the following which didnt work:
"Method": "EndAPISession",
"SessionToken": "#variable.Token#"
"SessionToken": #variable.Token#
is there a trick?
thanks!
tony
      Hi, did you check the value of the Token workflow variable under process monitoring to ensure it is correct? I believe hash variables are supported in the JSON tool, searched and found an example in Integration with UiPath Robotic Process Automation#Step4.ConfigureSecondTooltoStartJobUsingtheAccessToken.
